timeout error when reading from visa (com1: electrical load from Höcherl and Hackl)
I always got an error message when reading from visa. It is a timeout error which can´t be solved by increasing the timeout. What might be the problem? I´d like to programm an electrical load from H&H in LabView 6.1.
(2,728 Views)
That read error means that there's no data to be read at the serial port. The cause of that is probably because the instrument did not receive a valid command. Why it didn't could be because of any number of reasons. Is the baud rate, parity, data bits, correct? Is the cable correct? Are you sending the correct termination character? Is there a syntax error in the command? Have you tried using Hyperterminal?
A lot of questions with no definite answers but serial communication in general just plain sucks and there's a lot that can be wrong. If you would do a search of the forum for serial, you would see hundreds of questions similar to yours. Many of them have example code and links to tutorials such as the one here. I always start with Hyperterminal or Procomm to at least verify the hardware is correct before starting to write any software.
(2,728 Views)
