timer+counter
HI
I am trying to create a virtual timer+ counter,
I want the wave be counted in amount of time, for example 10 seconds.
Now I am trying two while loops.
one for timer, one for counter.
but it does not work.
Can anyone help me?
Thanks!
the attachment is the simple vi.
Message 1 of 17
(13,538 Views)
Hi cynitha,
you should think about the data flow. If you need parallel processes, then you have to use parallel loops, not one inside of another one.
Mike
Message 2 of 17
(13,533 Views)
Thanks for reply 🙂
I found what I want.
the attachment is the vi.
Now I want to add one more feature to the simple timer+counter.
I want to repeat the counter as many times as I want and save the info to a table. For example, run the program 5 seconds 10 times. The program stops with 10 counts data shown in the table.
Could you please provide any suggestion how to make it?
cynitha
Message 3 of 17
(13,486 Views)
Hi Cynthia,
Check out this vi and let me know whether it meets ur requirement or not .
Rgds,
Venky
Message 4 of 17
(13,476 Views)
Thanks for reply, Venky.
But I am afraid my expression was not clear.
What I want is to count the amount of the signal (pulses) in a certain time. and I can repeat the measurement as many times as I want. the final result can be shown in a table as the attachment, which repeats the measurement 5 times.
Could you please give any suggestion?
Cynitha
Message 5 of 17
(13,447 Views)
Accepted by topic author cynitha
Hi Cynthia,
Check out this vi and let me know.
Rgds,
Venky
Message 6 of 17
(13,429 Views)
Thanks very much! Venky
it is what I want!
Thanks for quick response, too.
Regards
Cynitha
Message 7 of 17
(13,407 Views)
Now I want to write the data to file.
could you please let me know how to make it?
Cynitha
Message 8 of 17
(13,401 Views)
Hi Cynthia,
check out this VI.
Rgds,
Venky
Message 9 of 17
(13,367 Views)
Thanks for reply, Venky. 🙂
Message 10 of 17
(13,353 Views)
