timer problem
Hello all,
I'm trying to add to my program the equivalent of a timestamp, except that it records the time elapsed from the start of the program...
like
 "press button" --> timer starts    writes: "0 seconds"
 "press button" --> timer records writes: "2 seconds"
etce tc...
I was thinking of subtracting 2 times... but I don't think it works. Any suggestions please?
thanks.
Aquaphire
---USING LABVIEW 6.1---
Message 1 of 26
(4,738 Views)
If you just want milliseconds, get the tick count at the start of the program (e.g. outside the main loop).
Inside the loop, you can now get the elapese time by using another tick count and subtracting the start value above.
Message 2 of 26
(4,734 Views)
Is it possible to set the tick count to 0 ?
Aquaphire
Message 3 of 26
(4,730 Views)
Aquaphire
Message 4 of 26
(4,730 Views)
In a way...  here's how to get the timer starting at 0.
Message 5 of 26
(4,726 Views)
Another question 😞
What IF (yes i know i'm being troublesome) I only wanted the timer to start the FIRST time I pressed the record button...? I can't really place it outside the loop because that wouldnt work...
Aquaphire
Message 6 of 26
(4,714 Views)
Well is your loop always running, or does it only run during "record"?
Message 7 of 26
(4,713 Views)
Well, One loop is always running. the other one isnt.
Let me attach my VI.
Aquaphire
Message 8 of 26
(4,709 Views)
Just do something like in the attached modification. (converted to LabVIEW 6.1). I hope it is clear.
Message 9 of 26
(4,699 Views)
Perfect! Many thanks 🙂
Aquaphire
Message 10 of 26
(4,694 Views)
