timer stoped by light sensor
I have a school science project that I'm doing to test the viscosity of liquids.  I am trying to make a program for my NXT 2.0 that triggers a timer right after a motor moves and drops a marble. Then stops the timer when the marble passes a light sensor at the bottom of a test tube. I can't figure out how to use the timer block and how to get it to display the time on the screen. I also don't know how to stop the timer when the marble passes the light sensor. Any help on the use of the NXT 2.0 timer block would be much appreciated.
 Please respond. Thank you!
(2,989 Views)
You'll probably have better luck posting top the Mindstorms board - http://forums.ni.com/t5/LabVIEW-for-LEGO-MINDSTORMS-and/bd-p/460
(2,939 Views)
