timer with pause option
Hello all,
I have designed a  elapsed timer VI with pause button but I need some other ways/strategies to have a Elapsed timer express function with the pause option. when the pause button is on it should be in pause state and pause button is off it should continue the action . pls find an attachment
(7,452 Views)
Hi bhuvanesh,
when you already do the "time counting" on your own you could get rid of the ElapsedTime ExpressVI…
(7,437 Views)
Hello gredw ,
i need some other method to crack this. That's why i posted in forum .
anyone viewing this . just post your methods
(7,424 Views)
Accepted by topic author Mrtechie
Several people I know have used the method here for their CLD timer:
http://www.labvolution.com/labview-cld-timing-engine/
It works whether you need pause function or not, and can be fairly easily memorised (subtract, add, select, select, gtoe). No case structures or enums needed.
Kudos to Greg.
Ian
LabVIEW since 2012
(7,408 Views)
thank u IAN for the eye opening link !! AMazing !!
(7,383 Views)
