timers that used for plc
  I want to use timers that use for plc.Timers starts to count when a boolean button turns on. When the button turns off, timers should be zero. (RESET)
              HELP? (VI)
(2,880 Views)
Hi Mehmed,
I'd recommend that you search through examples on the community site. One example program that I think you could use (with a very slight modification) is the Start and Stop Timer for Boolean Control program. Another example program that seems related is the Simple Stopwatch program. I'd recommend that you search the community for more examples or that you modify one of the examples I've listed here.
Sanjay C.
Embedded Software Product Manager| National Instruments
(2,857 Views)
