timing diagram
Please help me in plotting the timing diagram for 120,000 millisec range of x-axis.
The details are with the attached document.
Please go through that and provide the solution.
With Regards,
Padmavathi B.
(4,787 Views)
Is this a digital waveform you are going to write to a DAQ device?  What kind of output bandwidth will you have?
Your on/off times are to the 5th decimal of a 1 msec period., so you would need an output rate on the order of 100MHz.  120 msec would require a 12 million sample array.
You will need to create a couple For loops.  I would create a 9 element array that contains each of those times.  Feed that into a for loop, that creates an array of True/False arrays for each of those time period.  Feed that into another For loop that cycles through each of those 9 patterns and creates the final 12 million sample array.  These are large arrays, so I would do this using preinitialized arrays and replace array subsets.
See attached in LV 8.5
Message Edited by Ravens Fan on 03-14-2008 10:40 PM
(4,761 Views)
