timing in case structure
well try it with the way questionmarker has given ,
put your whole code (without while loop) inside the boolean - value change event and see.
I can explain it more clearly but i want you to learn and do it yourself.
Happy on discussing........
Message 11 of 18
(1,323 Views)
Fixed.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 18
(1,318 Views)
is this what you mean?
Message 13 of 18
(1,311 Views)
@ Yamaeda
i think the question is not about doing the things rather what is wrong in the attempt................
please continue the discussion till the person is satisfied.
Thanks.................
Message 14 of 18
(1,293 Views)
give him a fish or teach him how to fish...
To answer the question:
"i want different reactions, if boolean true, wait 5 seconds and execute, if false, then reset immediately, whats hard on that ?"
Absolutely nothing is hard on that. The Event Structure clearly is what you want to use; adjust it to your needs. I posted you a functional sample code, all you have to add is a case structure within with and without timer.It will work fine, though its not the best solution (try what happens if the user clicks faster than each 5 sec after you added your delay)
Besides; as you used the words execute and reset, I would reccomend have a look at queued step engines / queued state machine, maybe these design paterns may be useful for you.
I hope you can solve your problem with the hints given in this thread, enjoy!
Message 15 of 18
(1,288 Views)
@Questionmarker yes, looks like am little rusty on loops, will try to practice more on that.
Message 16 of 18
(1,267 Views)
thank you, @alok.p , will work harder on loops, and thanks more for insisting on doing it on my own.
Message 17 of 18
(1,266 Views)
B4S3M,
You are always welcomeSmiley Happy
Message 18 of 18
(1,258 Views)
