timing: labview time seems to come in bursts
I'm trying to sample some voltage signals at around 100-1000 Hz (using a PCI-6229) and simultaneously correlate these samples against an absolute time.
So, for example:
0.001 s, +1.0 V
0.002 s, +1.1 V
0.003 s, +1.2 V
0.004 s, +1.3 V
0.005 s, +1.4 V
...etc
However, when using the "Get Date/Time in Seconds" function in LabView, the timing comes in "bursts" like this:
0.047 s
0.063 s
0.063 s
0.062 s
0.078 s
0.078 s
0.078 s
0.078 s
0.094 s
0.094 s
This is regardless of whether I use the aforementioned function or if I read the data as a 1D Waveform and pull out the t0 values.
(2,327 Views)
Hmmm, never mind, got around the problem by switching to the "Tick Count (ms)" function.
But just out of curiosity, if someone could explain why the "Get Date/Time in Seconds" function behaves like that I'd appreciate it.
(2,323 Views)
That time comes from the Windows clock which has a resolution of only about 16 msec.
(2,309 Views)
