timing measurement between finite pulses
Hi Nitin,
I'm surprised you see anything at all in the chart when your "data" array is empty…
Did you do any debugging? Is there any error with the DAQmxRead function?
One note: you try to read 10k samples with a sample rate of 1kHz: this will take 10s. The default timeout of DAQmxRead is also 10s. Did you read the help for DAQmxRead regarding that matter? Again: did you do any debugging and did you check the error output?
Message 11 of 15
(1,204 Views)
Hi Gred
I am able to see samples now in array .
It would be grateful to you if you can let me know how i can search in rising edge in bunch of samples , as by the time i will process it one by one at the same time new samples will come .
Regards
nitin
Message 12 of 15
(1,150 Views)
Hi Gred
It would be grateful to you if you can let me know how i can search in rising edge in bunch of samples , as by the time i will process it one by one at the same time new samples will come  And ho wto trigger to count no of samples
Regards
nitin
Message 13 of 15
(1,134 Views)
hello Gerd
I can now traverse  the array and find out the transistions , But total transtion should be 22 , instead of them i am getting  less then 10 .
Can you please help me in this case ?
Regards
Nitin
Message 14 of 15
(1,089 Views)
Hi Nitin,
Right now you search in blocks of 100 samples: are you SURE you have more than 10 transitions per data block?
Can you attach an example with some data set to default in your VI?
Message 15 of 15
(1,084 Views)
