timing problem highligth modus work
got the timing problem
(3,237 Views)
Please Check with your code Prototype
Based on your Explanation First Warning comes when your counter is Lower than 2 then you should have the Limit for Upper Value, Like the same for Another warning both warning should have both upper and Lower Limits to decide the type of warning
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,230 Views)
