timing recovery vi
hi everybody i am aqib i am trying to install rf communication library which is available at the website(ni.com) but every time i installed it there is a problem that all the vi's which are supposed to be present in labview after installation are not been there for example psk timing recovery vi.what should i do? regards aqib
(2,842 Views)
One thing that might help would be for you to post links to what you are trying to download so tha we can see what you are doing. That might help point us in the right direction.
Tim
GHSP
(2,827 Views)
rf communication library is present at the following adress
http://decibel.ni.com/content/groups/ni-italy-system-engineers/blog/2010/01/22/labview-fpga-rf-commu...
where as the post which says that timing recovery vi must be present in this library is:
http://https://decibel.ni.com/content/docs/DOC-4068/version/12
regards
(2,817 Views)
Hi Aaquib,
 Which version of labview are you using?This library is meant for LabVIEW 2009 and LabVIEW 8.6 only.
SrikrishnaNF
Srikrishna
(2,806 Views)
