timing when using state machine
Here is the vi
Message 11 of 12
(935 Views)
You calculation of the Total Time happens in parallel with your reading for 0.2 seconds.  What you should do is pass out the last time used in the inner most while loop and subtract that and the start time.
You should also learn to use shift registers.  They are a little more efficient than using local variables.  Or you could just use a FOR loop for the outter while loop that is inside the Count state.
Message 12 of 12
(928 Views)
