timing
I have a timing problem that I am trying to figure out.  I am creating a functional test that is a period reading for my daq continuity check.  If my relay closes within 1000 ms I want it to stop my loop, pass and go onto the next test, but if it does not close within 1000ms I want it to stop the loop and pass the timout error to my pass fail button.  I cant get the timout to work.
(3,292 Views)
Can you post your code so that we can see what you already have? It will make it easier to offer suggestions.
Tim
GHSP
(3,271 Views)
Here is my vi it is in 2010 let me know if you need it in 2009.
(3,268 Views)
Hi tech11,
I have posted an example here that hopefully should put you on the right path.  I put notes in the case structures where you would have to add code and you will have to add the boolean invoke node functionality as well (There was a sub VI called from the main VI that I did not have).  I hope this helps!
Kim
(3,245 Views)
