timing
hi
  I am working with autofocussing of an image. I got struck at one point in my project which is not allowing me to go further. I wrote my code for autofocussing,it is working quite well when i disturb my image in one direction(clockwise). I am using joystick for my testing purpose. The problem is, when i disturb the image in other direction(anticlockwise) then my autofocussing code is getting failed and it is coming out of the loop. Strange thing here is even in anticlockwise direction,in highlight execution mode it is working properly. Will there be any timing issues or anyother modifications to be done. Any suggestions are welcomed.
(2,815 Views)
Hi Saminemi,
you should stick with your original thread(threads in fact), that way it's much easier to give relevant answers and not re-iterate through all answers alredy given...
Then you should also learn to give meaningful thread titles, "timing" is very generic and has (nearly) nothing to do with your question...
(2,812 Views)
hi,
   my problem is not yet solved. I am unable to find where i might have gone wrong. Can u guide me in solving this problem.
(2,806 Views)
