tipstrip Customization
Hi all,
Is there a way to customize the tipstrips that appear in LabVIEW windows? Perhaps, an ini file setting? In particular I wish to change the time period of mouse-hover after which a tipstrip appears. This may appear when the mouse-hovers over a listbox with text that exceeds the column length.
Priyadarsini S
(2,529 Views)
I don't think you can. I would love to know if it is possible!
In the meantime there is a workaround. I put an example here http://forums.ni.com/t5/BreakPoint/What-did-YOU-learn-today-Get-your-Daily-Micro-Nuggets-here/m-p/14...
LabVIEW 2012
(2,526 Views)
