titles and graphs
Is there a way to associate a title with a 2D-Axis object? In other words.. Are there other ways to add a title/ heading to the graph other than by inserting it as a "Free-Text"
(2,493 Views)
I am not sure if i understand what you want to do.
You can use the Graph 'Caption' right-click on the graph 'Visible Items -->Caption' (move the Label text so you can see the Caption text).
Then you can use the 'Create--->Property Node---->Caption--->Text and write to that any text you want programatically.
Hope that helps.
Regards
(2,454 Views)
Thanks for the reply. I've atached an image of an example. I wanted to know if the circled portion, which is a heading for the graph can be associated with the graph itself, like a property of a "2D-Axis" or "2D curve" object, or does it have to be placed on the report as a "Free-text" object
(2,439 Views)
