.tlb and .log file
Hello everyone,
Recently I have made an exe of one of my project. Normally when we make exe 3 files gets generated  ".exe", "Aliases", ".ini"
But in my case 2 more files were generated ".log" and ".tlb". Can anyone tell me what are these files?
If these files are not there, then my exe gives out error.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,755 Views)
Can someone from NI answer this?
Gaurav k
CLD Certified !!!!!
(3,738 Views)
Are you enabling the ActiveX server for the application? .tlb is normally a type library, which applies to ActiveX.
(3,734 Views)
hey,Have you solve the problem?
i get the same case.
(1,927 Views)
