to calculate the percentiles of a data column
Hello!
I want to calculate the percentile 25 and 75   or (25%, 75%) of a data colum's. There is some labview block to calculate it. Someone knows somw way to calculate using another statistical labview block and then obtain the values i want.
Thank you very much.
Larson
(2,579 Views)
convert the column into an array of numbers, sort the array, take the size of the array and divide by 4, this gives you the index of the first quartile, x2 is the second quartile, x3 is the third.
(2,572 Views)
