to check the total execution time in performing task
hi
   i just want to know that how to check the total time taken to perform a task in labview .For example if i am using a while loop and inside it i am performing any addition task then how much time it will take to execute a loop single time
Message 1 of 8
(3,143 Views)
Hi venky,
get the difference of time after and before loop and divide by the number of iterations...
(And this is one of the seldom occasions to use a sequence structure!)
Message Edited by GerdW on 05-11-2010 08:11 AM
Message 2 of 8
(3,132 Views)
hi,
  sud u help me out how to do this i didn't get this as i have to use while loop.pls its urgent
Message 3 of 8
(3,129 Views)
Hi venky,
when I search for "measure time" here in the forum the first result I get presented is this!
What did you get when searching the forum?
Message 4 of 8
(3,125 Views)
Please check the attached VI ... it may help you
Message 5 of 8
(3,118 Views)
hi,
   well i will go through your suggestions .hereby i am uploading the png file of my work please go through it and help me out that how to calculate the total time execution during single cycle.
Message 6 of 8
(3,099 Views)
Hi venky,
do the same as was suggested in thread I linked before. Your sequence structure replaces the (3rd) frame containing the "Wave play" in the other example...
Or to put it in general words: measure time before your sequence and after the sequence to get the difference...
Btw. are you sure you have to send individual bytes?
Message Edited by GerdW on 05-11-2010 01:16 PM
Message 7 of 8
(3,095 Views)
hi,
      thanks i will follow what u wrote and meanwhile, yes i have to provide individual bytes and these values is to be given to microcontroller.
thanks
Message 8 of 8
(3,079 Views)
