to get values from graph in labview
Hi everybody.
Please help to solve my problem.
I need to get values from graph in labview. Is it possible?
Message 1 of 11
(10,949 Views)
The values at a single point selected by the user?  If so, look at cursors.
The values of all data points? If so either use the data that is wired into the graph, or (less desirable) read from a local variable.
Can you be a bit more specific about what you want to do?
Message 2 of 11
(10,947 Views)
Thanks for reply. Now I'm going to introduce my problem.
I have, for example, XY graph. I need to get the value of Y corresponding to given X value.
Thank you in advance.
Message 3 of 11
(10,933 Views)
Accepted by topic author Moony
It still isn't quite clear how you want to provide the 'x' data. For example, the attached show two possible methods.
Ian
Message 4 of 11
(10,923 Views)
Look.
I plotted a graph with certain known X-axis values and its corresponding known Y-axis values. I need to find out the corresponding value on Y-axis for a specific value on X-axis. In other words, I want to input X-axis value and then to know corresponding Y-axis value.
Thanks for example. I'll study it.
Message 5 of 11
(10,910 Views)
Dear lan,
Thaaaaaaaaaaaanks soooooooooo much!!!   Smiley Very Happy
Your example is all I need...
Thanks once more.
Message 6 of 11
(10,883 Views)
Hi
I have the same problem,Can you send a picture of the solution?my labview is 8.2 , It can not open the solution.
thanks
Message 7 of 11
(10,600 Views)
Ere ya go.
Note that you could also perform these operations within an event structure in order avoid the continuous while loop.
Ian
Message 8 of 11
(10,588 Views)
Thank you veryyyyyyyyy much!
Message 9 of 11
(10,583 Views)
how would you do the same but knowing the y value and looking the x value?
Message 10 of 11
(9,660 Views)
