to play a wave file with system sound
I have to play a sound everytime an alarm occurs, but the PC doesnt have either a sound card or speakers. The "beep.vi" works on the PC but the sound it creates is too short and week. I want a longer and stronger sound that gives an alarm warning sound.
Is there anyway I can do this?
(3,255 Views)
try to put it into for loop. Look how much cycles you want.
(3,255 Views)
I tried that, but that is not what I am looking for. I want it to give any typical sound but not a series of beeps. If there is no way of doing that then I will stick to the series of beeps
Thanks anyways
(3,255 Views)
Beep.VI sends a command to make the default beep in Windows. I have a built in sound card, but I imagine changing the windows setting will work. Goto the control panel >> sounds and multimedia and change default beep to any file of your choice.
Jeremy Braden
(3,255 Views)
I built a beep-function in the past (using port in/out vi's), so it will probably not work on the more recent Windows O.S.'s. It was used on a PC-based depth-meter.
As I remember you can start a beep by calling the vi and another call makes it stop.
If your interested I can look up the code.
Patrick de Boevere
(3,255 Views)
Thank you Patrick, but I have sorted out my problem to some extent.
(3,255 Views)
