to run the exe on labview
Hello NI, I want to run the (thirdparty) exe file using labiview command. but, the exe file should be visualize with in the vi like sub vi, not independently. is there any like a activex container to be execute ? Example, if i want to run the notpad.exe file, that should be visible on within the labview VI. like we creating subvi... Suggest me.
Balaji DP
(2,599 Views)
(2,595 Views)
