to run thirdparty exe in labview
Hello NI,
                  I want to run the (thirdparty) exe file using labiview command. but, the exe file should be visualize with in the vi like sub vi, not independently.  is there any like a activex container to be execute ?
Example, if i want to run the notpad.exe file, that should be visible on within the labview VI. like  we creating subvi...
Suggest me.
Balaji DP
(2,657 Views)
You can use "system exec.vi" to run the third party applications. Go to connectivity->  Libraries& executables -> system exec.vi
let me know if this was useful to you
-Mallya
" Appreciate and motivate those who help"
(2,613 Views)
