to store data in excel format using write to spreadsheet file
I get to store a 2d array of data using the write to spreadsheet function.When I open the excel file later and do some modification and want to save them bac, I get a series of file dialog asking to be saved in excel format.How to i override this and get to store my 2d array in excel format directly instead of in the text format as done by the write to spreadsheet function.
(3,195 Views)
You will need to store your data directly to an excel sheet via activeX.
Try looking at the examples with LabVIEW in particular Write Table to XL.vi found in C:\Program Files\National Instruments\LabVIEW\examples\comm\ExcelExamples.llb.
Also, you might try doing a search in this forums as I know there has been questions like this before and there are probably more examples.
Hope this helps.
Regards
Ray Farmer
Regards
Ray Farmer
(3,195 Views)
