to string subset
Hello I'm using the string subset block, but i want to obtain the substring before the offset,......for example
initial string=wonderful
offset=4
I want to obtain wond..........but with this block i obtain erful.
What can i do??
Thank you very much
Larson
(2,685 Views)
Leave the offset terminal at 0 and wire the 4 to the length terminal.
(2,680 Views)
Hi Larson,
Look at attached Vi
regards
Dev
(2,677 Views)
Or you could use "Search/Split String" on the "String -> Additional String Functions" pallette.
Simon
(2,675 Views)
