toggle LED after time delay
I have a Control LED and an Indicator LED.
How can I set the Indicator to be False then after 5 seconds to be True again when the Control logic is True?
(5,838 Views)
Sorry forgot to mention when the Control LED is False the Indicator LED will be False
(5,834 Views)
See attached file
(5,812 Views)
KateB, That is an excellent solution.
Fantastic! Elegant code, really
You should write some explaination in. It actually beats the 'timed loop' usage. Many posts on the site are about this ina roundabout way.
Appreciated!
(5,562 Views)
Here's making it really flexible. All the hardwork from Kate makes it a sub-VI.
This one is set for 10 seconds. Stick a connector to make the time variable through the 'show connector'
(5,558 Views)
