toggle switch on iteration
I want a case statement to toggle between true and false every iteration of the for loop it is in.  How do you do this?
(4,419 Views)
IN your while loop, run the iterator into a Quotent and Remainder with a divisor of 2.  The result will be a 0 or 1.  Run that into a =0 and you have a true/false.
Hope that this helps,
Bob Young
(4,414 Views)
Or, use a shift register and a Not.
Message Edited by jasonhill on 05-12-2006 01:40 PM
(4,412 Views)
Yours is better but mine was first Smiley Very Happy
No, seriously, this is probably a better idea.  I bet there can be many, many, other ideas as well.
Bob Young
(4,404 Views)
Thats what I love about LabView, so many ways to solve the same problem.  I suspect that all sorts of people are going to come out of the woodworks to suggest increasingly bizzare ways to solve this one.
(4,394 Views)
Sounds like another obfuscated code challenge!Smiley Very Happy
(4,387 Views)
Here is another take.
Cheers,
--Russ
Message Edited by Russ Evans on 05-12-2006 03:46 PM
(4,374 Views)
