too many ocr sessions
Hi
Does anyone know how to solve the error message "there are too many ocr sessions open" error code 1074395214?
I assume its because I'm doing OCR in a while loop so it opens a new session ever loop but I don't know how to close a session
Nick
(3,723 Views)
Check this document:
NI Vision Error Codes
Pharaphrasing it: "There are too many OCR sessions open. You must close a session before you can open another one."
Check the Vision Palette and search for some VI that closes your session.
If you don't mind, could you post your VI? I can't help you by applying the correct block because I don't have Vision in my suite. But I'm sure you will get some help.
Best Regards
Mondoni
(3,705 Views)
