too many plots
I have a 1-D array of 8 doubles, which I then convert to a cluster and then wire to a chart. However, my chart gives _9_ plots (I'm stacking), the last of which simply reads zero.
Where did this extra plot come from, and how do I get rid of it?
(2,974 Views)
Right-click the "Array to Cluster" function and
enter the desire cluster size... (it is def. at 9, I think)
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(2,974 Views)
I have often had problems changing the number of elements in a cluster in this way. I have often, and reprodicibly had crashes when changing the number of elements in an "Array to cluster" function which is wired up. I always un-wire the function fitst, change the settings and then re-wire.
Maybe this is fixed now, but then again, maybe not.
If you experience a crash, this work-around should do it.
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(2,974 Views)
