too much time to run Matlab script inside Labview
If I execute a matlab script inside matlab, it takes less than 1 second, while if i put the same script inside a Labview program, it takes something like 20 seconds. This is not acceptable for my application. Is there something that i can do to speed up my program?
Thak you
(2,726 Views)
Salutations,
Why yes, Write your script in LabView, that way it doesn't have to call up matlab to run it etc...
Sincerely,
ElSmitho
(2,715 Views)
Hi Bella
Most of the time is "wasted" in loading matlab, load it beforehand and it is very fast.
Albert
greetings from the Netherlands
(2,712 Views)
