tool palette line length
Hello!
I wonder if it is possible to draw a line with the tool "LINE" and the design of this line to know the size and angle of it?
Can I do it but with the tool "IMAQ Select Line", opening a new window and drawing a line.
But I want to draw directly on the "Tools Palette" and wonder if it is possible to do this.
I am using Labview with the Development Vision 2010.
thank you
(2,601 Views)
By the tool "LINE" are you referring to the Line tool under the Decorations palette on the front panel?
If so, I don't think you can get the angle of the line but you can get the size and position of decorations.
I would suggest starting here: http://digital.ni.com/public.nsf/allkb/6099CCE209178322862570C0007DA0F1
I have included a sample UI that shows the height and width of a Line decoration on the front panel.
Happy Pi Day.
(2,567 Views)
Thank you for your solution, but how could I apply this same function to the tool palette tools PICTURE (IMAQ).
I need to apply this same function however the image editing tool "Line."
(2,557 Views)
