tortoiseSVN committed files that weren't changed and corrupted them
Hi all,
A colleague used my working copy to perform some changes. He then committed everything. Even though he did not change the classes in a subfolder, TSVN committed them as well. All the classes are now corrupt - the Class VIs do not recognize the class (attached). This is for every class in the project.
To make sure nothing was in fact changed I used lvdiff and the TSVN log, and no differences are shown and both versions show a broken arrow (even though the previous version worked fine).
If I try to go back to the previous revision in the working copy, it doesn't work (still a broken arrow). Only if I take a completely new folder and checkout the older revision do I get my classes back. However, the updates my colleaugue did are important.
Does anyone have any idea what could cause this, what I can do about it and how I can prevent this happening again?
Danielle
"Wisdom comes from experience. Experience is often a result of lack of wisdom.”
― Terry Pratchett
Message 1 of 1
(2,203 Views)
