touch panel
Hello all
I have LV8 , Touch Panel module and HMI Touch Panel "EBOX 2300" -WIN CE, (2-COM, 3-USB)., made  "ICOP"
I created and install it on HMI Touch Panel "EBOX 2300".  The application is worked .
I want to work with COM or USB.
Then I want to install on  EBOX 2300 - NI VISA.
And I received the ERROR, - "Faled to connect to the remote device".
I can't to connect EBOX 2300 to my computer.
I copied the application throught USB Flash.
How can I install support for NI VISA to EBOX 2300?
Regards
Iskander
(4,022 Views)
Hello Iskander,
You must install the VISA driver through the Start Menu to use VISA on your touch panel device.
To do this, select Start»All Programs»National Instruments»VISA and select Windows CE for ARM Driver Installation or Windows CE for x86 Driver Installation, depending on which type of target the EBOX 2300 is using.
Please let me know if you have any other questions, thanks!
Erik
(3,997 Views)
Thanks for the answer
Happy New Year
I will be try
Regards
IskanderSmiley Happy
(3,977 Views)
Hello
EBOX-2300 haven't connect with my PC.
Because I don't install VISA.
I can install  VISA via USB-Flahs
Regards
Iskander
(3,958 Views)
Hello Iskander,
Happy New Year to you too!
Were you able to successfully install NI-VISA using USB Flash?  If not, I would recommend installing NI-VISA 4.2 on your PC, then using the utility I described above.
Please let me know if you need any further assistance!
Kind Regards,
Erik
(3,926 Views)
