trace maximum value for few samples
hello,
i have a problem with how to trace a maximum value in certain range of samples,
i have done a programming of multi peak and threshold detector, but how i can
change this program to make it detect the maximum value each time its
samples like about for 50 samples. Also, i have include the ring function,
if the maximum value is to be get like 8.5, so it is in range of 8-10 scale,
so can the ring function have ranging scale? or i need to use other
technique?
i have also attached the program i have made and also the picture of
data that i need to trace the maximum value.
device: LVDT
output: analog voltage
LabVIEW 8.0
from,
zull azym
UTHM Reseacher,
Malaysia
(3,799 Views)
For an 1D array you can use "Array max & min" function. It's the best way.
You can use the "Array Subset" function to get the 50 desired samples and then use  "Array max & min"
(3,793 Views)
About the ring function , i am not sure what you mean, but you can use something like that to change the value of the ring according to an input number
(3,788 Views)
hello n thanks for a quick replies. I try to search for array max n min and i did'nt get the idea,
could u please give me u guide or example for me so i can
study the architecture of it.
for the ring function, actually i want to make
an analysis programming which shows like this:
value: 0-2: good
          2-4: best
so, if used ring i only can make: 1: good
                                                    2: best
so i cannot make a range value using ring function.
hope u get my ideas.
regards,
zull azym
UTHM Researcher,
Malaysia
(3,767 Views)
-The max & min function is in the "Array" pallete.
-You can use a string indicator, or you can change the ring text as shown...
(3,758 Views)
duplicate post...
(3,740 Views)
