I suggested a mass compile because of the error message you received: "the call back vi is too old for my ver of lab view". If the Test Executive can't find some VI's, that may be another problem.
Did your hard disk crash or did Windows just crash?
Did you reinstall your VI's or just the Test Executive?
Are you sure you reinstalled your VI's into their previous directories?
Did you need to reinstall LabView?
Are the VI search paths different now? See the search path in LabView 6.1 at Tools >> Options >> Paths >> VI Search Path.
If LabView can't find a sub VI, it will show you the complete original path to the VI (including the LLB file, if any) while it's searching. After completing an unsuccessful search, a file dialog will open asking yo
u to find the missing VI. In that dialog, it shows only the vi name, not the complete path. But you can move that dialog out of the way to see the complete path in the search dialog behind it.
If you realize that the VI or LLB was moved and you want to restore the original location, you can stop the VI load, exit LabView, move the VI or LLB using Windows Explorer, restart LabView and load your application. If you want to use the new location, browse to the new location to locate the VI when LabView prompts you to find the VI. After the load is complete, exit LabView. It will prompt you to save calling VI's recompiled because sub-VI's were moved. After that save, LabView will find the VI's next time you load your program.
