track several object at the same time
Hi everybody,
I`m actually trying to tracking several same objects at the same time.
I knew how to do with only one object, and I was able to send the coordinate for each frame in excel. So great.
But now I`m trying to modifiy the code to follow eight objects at the same time.....
My code was already HUGE with one or two objects, but I need to add again 6 part of the same code....
I would like to compact and contract my code to be more clear.....
I suppose there is one solution juste after Labview vision assistant. And i`m sure that there is a way to put all the code to delete the zeros in only one for loop but I didn`nt find the right way....
Anyway if there are some propositions or some ideas, advices..... it`s welcoming
Thks a lot
Sincerely
Maxime
ps: I put my codewith only two patterns
Message 1 of 1
(2,701 Views)
