08-20-2009 06:56 AM
after doing an installation of LV2009 and it's DeviceDrivers I missed the traditional DAQ functions... Even trying to re-install (or update) the traditionalDAQ didn't work.
So:
Is TradDAQ support dropped starting from LV2009? I couldn't find information on this in the upgrade notes...
Possible workaround:
Described here: Working in the opposite direction as described I copied the files from my LV8.6 to the LV2009 folder...
Solved! Go to Solution.
08-20-2009 07:54 AM - edited 08-20-2009 07:55 AM
Gerd,
This lists NI-DAQ (Traditional) 7.4.4 as being a compatible driver version. No mention as to how to install it with 2009.
08-21-2009 02:53 AM
hi gerd,
i found a knowledgebase which says what to do in this case:
http://digital.ni.com/public.nsf/allkb/7B916CC4A067997D862574BB000E2AB5?OpenDocument
with kind regards
patrick
08-21-2009 07:15 AM
