transferring waveform data from a current loop to an outside
I am relatively new to labview and was in need of some aid; i have already talked to NI engineers and we didn'e come up with an easy solution to this, so please lend your expertise if you can.
I currently have a functioning program inside a while loop that I am looking to modify.   I'm grabbing some waveform data and will perform some mathematical operations on it.
My question is what is the best way to grab that data in real-time and transfer it into another loop (which would do the operations on that data that i need).  We tried some queue functions but apparently there were some timing issues, etc. that apparently didn't work.  In case you are wondering why I am trying to grab this waveform data into a new loop, I will be taking averages of the maxes and mins of the waveform and calculating a new average every 4 seconds.  I believe i can come up with an algorithm to compute this; its just getting the data to feed in accurately from the original waveform.
Please let me know if you have a way to do this or have any words of wisdom; it would be very greatly appreciated.
(2,864 Views)
I'm probably just over simplifying this, but the main loop is running continuosly, and every 4 seconds, you want to compute some averages? Why not just have a timer running that executes a case structure then resets the timer?
Of course, anytime someone uses the word "real time" my eyes get all glassy and my brain stops because I never really know what that means. I assume I'm always writing programs that are "fake" time or something like that.
Paul Johnson
Renco Encoders, Inc
Goleta, CA
(2,852 Views)
HI ksm,
are they too many data, that you don't work with local variables? I don't know how "real time" that is.
Smal working example attached.
(2,846 Views)
Queues should work. Look at the shipping examples of Producer/Consumer design pattern which use queues. If you have a very large dataset an Action Engine as described in Ben's recent Nugget might be useful in preventing unnecessary data copies.
Lynn
(2,837 Views)
