transmit image using wifi
Hello i Have two codes that are used in order to transmit images using ZigBee the one act as a receiver and the other as the sender. I would like to ask you if you can help me convert this two codes from serial to wireless communication in order to transmit the images using Wi-Fi
Thanks in advance
Please find attached my codes
(2,438 Views)
Hi Ariadni,
and why don't you stick with your original thread?
(2,434 Views)
