transpose 1d array
It sounds kind of dumb, btu when Iave the 1d array or 1d string, it saves it as a row instead of column.  I know how to do that for a 2d array since they have that transpose 2d.  But how do you do for a 2d string or 1d string? thank you very much.
Message 1 of 8
(8,890 Views)
If you use "write to spreadsheet file", wire a TRUE diagram constant to the "transpose?" input.
If you do your own formatting, use a newline ("\n" in '\'-code display) as delimiter.
Message Edited by altenbach on 11-04-2005 02:36 PM
Message 2 of 8
(8,881 Views)
I use "write file"
Here i attached the VI, it is really messy, but you can see on the last case my labview code.
Message Edited by Akatsuki on 11-04-2005 04:39 PM
Message 3 of 8
(8,880 Views)
As I added in my answer above, you just need to use a different delimiter to sepearate your elements (newline in this case).
Message 4 of 8
(8,876 Views)
is there a tutorial on how to use these codes that you are talking about? I tried to put \n but it does not go to the line.
Message 5 of 8
(8,871 Views)
You need to set the string indicator or diagram constant to show '\'-codes. Right-click to modify.
Message 6 of 8
(8,864 Views)
Is it possible to get an example of it? Thank you.
Message 7 of 8
(8,859 Views)
Well, until you posted your VI, I did not know how you were formatting your strings. THere are many possibilities. 🙂
I cannot make sense out of your VI, but maybe all you need is to append a linefeed to each string array element. This can be achieved by placing a FOR loop as shown in the attached modification of your VI.
See if it works.
Message 8 of 8
(8,853 Views)
