transposing 2D array
Hi I have tried so many different things with this that i have got myself really confused,  what i am trying to do is transpose chucks on data see below for an data example.  i have tried to do this using for loops with indexing and by not using indexing.
the data is
Test Name Min  Max Result
Test 1 1 5 3
Test 2 2 6 5
Test 3 3 7 4
Test 4 4 8 5
Test 1 1 5 3.5
Test 2 2 6 4
Test 3 3 7 5
Test 4 4 8 6
Test 1 1 5 2
Test 2 2 6 3
Test 3 3 7 5
Test 4 4 8 4.5
 and i want it to be transposed like this,
Test Name Test 1 Test 2 Test 3 Test 4
Min  1 2 3 4
Max 5 6 7 8
Result 3 5 4 5
Result 3.5 4 5 6
result 2 3 5 4.5
can anyone point me in the right direction.
Message 1 of 25
(9,052 Views)
No.  Because you haven't given us any VI to look at to see where the problem is in your program.
Message 2 of 25
(9,033 Views)
How about the transpose array vi?
Greetings from Germany
Henrik
LV since v3.1
Message 3 of 25
(9,027 Views)
That's because i don't have a vi!
I am looking for a starting point.  i was hoping from the data i posted someone could suggest a way to do this.  i am not looking for someone to do this for me but shove me in the right direction.
Message 4 of 25
(9,025 Views)
if i use transpose, that the data it transposes all of it i am looking to transpose chunks of it based on the test name
Message 5 of 25
(9,024 Views)
We have no idea of the data structure you are using to hold the data (though it seems "natural" to me that it would be a 2D array of dbls).  We have no idea if you realize there is a Transpose 2D Array function on the Array Palette.  We have no idea if you are trying to write a file (and is it a "Spreadsheet file", a Text file, an Excel WorkSheet, or something else), and have no idea if some of the rows/columns represent data or are measures derived from the data.
Attaching your VI attempt (do not attach a "picture" of the Block Diagram) would possibly give us some clues.  A better description of what you are trying to do would also help.
Bob "I don't understand the Question" Schor
Message 6 of 25
(9,021 Views)
But you do have a starting point.  You have whatever you have done so far that is not working for you.  How can you have something working wrong if you don't have a VI?
We can't shove you in the right direction because without code, we don't know which is the wrong direction you are already heading.
Smiley Frustrated
Message 7 of 25
(9,017 Views)
i understand your trying to help but you don't need to know the information your asking, the data i choose is arbitrary it can be anything its just the concept i am after trying to solve.  a post or 2 back i do mention transpose 2d array but this doesn't help me initially due to the way it works.  i didn't mention anything about writing to files that's irrelevant.
what i was asking was based on the data i posted as an 2d array
Message 8 of 25
(9,015 Views)
instead of telling me to post code that i don't have because i don't know where to start.  can i then ask how would you start to solve the problem i posted in the first post?
it is a 2d array lets say its a string what would i do the the first array to make it like the second?
Message 9 of 25
(9,012 Views)
But you DO have code!
In your original message you said:
"I have tried so many different things with this that i have got myself really confused,  what i am trying to do is transpose chucks on data see below for an data example.  i have tried to do this using for loops with indexing and by not using indexing."
So you have tried something, where is that code?
Message 10 of 25
(9,008 Views)
