tree control bug for vertical scrollbar
Dear all:
I meet a problem with  tree control  vertical scrollbar.Pls check the picture
If set the rows of the properties of the Tree control is a number, also set the vertical scroll bar is visible.
Then if i set the height  of Tree is unchangeable, then set the Tree childs rows are  much more than the height, The problem is that  the vertical scroll bar doesn't work. The height is increase than what i have set ,Maybe it is a bug? or not.
Anybody find this?
(3,095 Views)
up to the top,somebody can help meSmiley Happy
(3,080 Views)
I works fine with me.
But I added my test as attachment, so you can see if you maybe doing something else.
Kind regards,
André
André (CLA, CLED)
(3,079 Views)
