tree control choose a tag by more than one parent tag
The *.txt are filr required for the data loading to put it in the tree
Julien
Conception Informatique et électronique
CNRS LCSR Web
Orléans la Source FRANCE
Message 11 of 15
(2,205 Views)
and then the VI
Julien
CNRS LCSR Web
Message 12 of 15
(2,205 Views)
ok
i HAVE FOUND MY ISSUE Solution....
The value which determinate the parent tag got some space character ...
When the attibution for son tag are made, I use those values (with space) whereas the tree method node delete the space, before and after the string of the parent tag (during the first attribution )....
Julien
CNRS LCSR Web
Message 13 of 15
(2,199 Views)
The Vi unless error but not ended to the final objectif
Julien
CNRS LCSR Web
Message 14 of 15
(2,197 Views)
and If you are interesseted by my works , know that this VI aims to select and built unit available by labview (with no problem of syntax...)
and you will need this file whe sum up all the units of labview (domain, name of the unit and his labview syntax), the first Unit Labview.txt contains an erro which make stop the tree classification before the end...
I search the french version of this file (Unit Labview.txt)
With my pleasure regards
Julien
CNRS LCSR Web
Message 15 of 15
(2,195 Views)
