tree control size change
Hello, The bounds-property for a tree control is read-only. How do I change the size of a tree control to reflect a context change and display a table next to it. Alternatively, changing the position of the vertical scrollbar might be an option, but I have little hope finding that in lv. Thanks.
(2,961 Views)
Hello Asche,
If you want to resize a tree control when you show another control (such as a table), you can use NumCols and NumRows properties.
I hope the example explains it sufficiently.
(2,961 Views)
Works like a charm. Kind of a strange way of thinking and not really obvious from the documentation. Thank you very much.
(2,961 Views)
