tree item to another tree!
hi,
does anyone know if there is a function which can copy selected items from a tree to another. i know that there is a drag & drop function that can handle this, but with this function i can drop this items everywhere on my frontpanel, i don't want this. so i thought about a function that can copy all selected items from a tree to another by clicking a button. and with another button you can delete these copied item again.
how can i do this? i read in a post, that there is a function called "CopyTreeItem" that can do these things but just in labwindows, but i don't have this software!
hope someone can help me,
thanks a lot,
simon
(3,015 Views)
Now, I m into more confusion...
Do you want this to be done in LabVIEW or LabWindows/CVI? Smiley Indifferent
Both are different programming languages. If it is the latter, this is NOT the correct forum to get optimal responses. Smiley Wink
If it is LabVIEW, then also you must have it to do it. Smiley Happy
- Partha ( CLD until Oct 2027 🙂 )
(2,996 Views)
no, i don't want to do this in labwindows.
i want to programm it in labview, but i'm not sure how to handle it!
so i'm pleased about any reply.
thanks,
simon
(2,972 Views)
See the attached VI.
Modify as per your req...
(2,948 Views)
thanks for your help,
i'll try your example and modify it for my problem.
regards,
simon
(2,933 Views)
