triangle in enum
What does that little triangle in the upper left corner of an enum signify? Goes it mean that the enum is type cast like in a refnum?
(2,807 Views)
Not "type cast".
It means it has a type definition.
(2,806 Views)
It is linked to a Type Defined (Type Def) control file (.ctl).
(2,730 Views)
It means it's a separate file and you can r-click it and select "Open type def". If you change the type def all instances of the enum is thus updated. Quite nifty.
Qestit Systems
Certified-LabVIEW-Developer
(2,710 Views)
