trigged signal generation on multiple channels
I want to generate two different analog signals on two different output channles when I recieve a trigger signal. I have tried to modify the "Cont Generation - E-series A-trig.vi"-example to work with more than one channel. My signals are an 2D-array with the signals to channel one in the first column and the second channel in the second column. When I try this I see that my signals on the second channel is not what I expect. If anyone know what I do wrong, or maybe know how to solve this problem in another way, please tell me. Thank you. I have a DAQCard-6036E.
Message 1 of 1
(2,360 Views)
