trigger and gate
Hi friends,
I use trigger and gate function. the signal is cut in the trigger level value. I would like that the signal isn't cut in the trigger level and this function is only triggered the signal. for this what can I do?
Have a nice work
(3,572 Views)
Please provide a VI and maybe a picture to show  what is happening.
(3,566 Views)
For example, When the trigger level is  0.5, the signal is cut in this value.
(3,559 Views)
Are you wanting to see data from before the sample that triggers the acquisition? I'm not sure what you mean by "cut".
(3,544 Views)
I can see the signal before trigger. for trigger, Is there a different function?
(3,540 Views)
