trigger for two camera simutanously
Hi there,
how i trigger two camera simultanously to capture images in the same time exactly?
i use frame grabber NI CVS-1457RT , two cameras (GigE vision) on realtime.
i've found an example vi "HL Grab with two boards.vi" but its not compatible with the cvs.
another question, where can i find a tutorials about  cvs an FPGA to acquire an image?
i am using LabVIEW 2015, LabVIEW FPGA and Realtime.
thank you
(3,639 Views)
HI there!
Google gives you plenty of results 🙂
Triggering:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x0UsCAI&l=en-US
You also can do it in LV using property node.
Getting Started Vision FPGA:
https://www.ni.com/en/shop/data-acquisition-and-control/add-ons-for-data-acquisition-and-control/wha...
https://forums.ni.com/t5/Past-NIWeek-Sessions/Getting-Started-With-LabVIEW-FPGA-for-Vision-Applicati...
NI propose also a new Vision course since 2014 if I remember well, let's have a look at it.
Hope that is helping you.
Certified LabVIEW Architect (CLA)
(3,596 Views)
With many cameras you can send a software trigger so that they acquire at approximately the same time. Or are you trying to use a hardware trigger?
(3,556 Views)
